Activity Forums Apple Final Cut Pro Legacy compressor cannot connect to background process
  • compressor cannot connect to background process
    Posted by Mark Madsen on June 27, 2008 at 7:45 pm
    i have a project that i’m trying to export. i usually like to use compressor, but every time i try to export it, it says that it cannot connect to the background process. i tried exporting using quicktime and quicktime conversion as well, but they keep coming out without the video being visible.
    any suggestions?
    thanks
    Mark Madsen replied 18 years, 2 months ago 3 Members · 3 Replies
  • Ed Dooley
    June 27, 2008 at 9:12 pm
    See that little search window up and to the right? If you type cannot connect to the background process, or just background process, you’ll get advice (2 of the tips are mine, from 2 years ago, and guess what they say? “Do a search” because even 2 years ago it was happening) The Compression Forum has the best answers, including a link to the Apple forums discussion of this very old, very well discuused issue. The Apple link is the best solution because it depends on which version of Compressor you have
    Ed
  • Jeremy Garchow
    June 28, 2008 at 2:29 am
  • Mark Madsen
    June 28, 2008 at 2:41 am
    thanks guys. i went to the apple site and am following the instructions.
