Activity Forums Compression Techniques Compressor – Burn Blu-ray with EXISTING H.264 file
  • Compressor – Burn Blu-ray with EXISTING H.264 file
    Posted by Ethan Young on May 18, 2011 at 2:10 am
    I frequently create Blu-ray discs of projects for clients using FCP>Compressor. I always have requests for additional Blu-ray copies in the weeks following.
    But after waiting nearly 4 hours for a 90 minute ProRes QT master to encode into H.264/AC3 and burn a disc, I would really prefer not to have to go through the encoding process each time a new BD is requested.
    After the initial encode batch job with Compressor I have the H.264/AC3 files stored. Is there some way to use Compressor to just burn a one-off by simply using the existing H.264 I have already spent 3 hours encoding?
    Does anyone know how to do this?
    Patrick Mi replied 7 years, 7 months ago 8 Members · 12 Replies
  • 12 Replies
  • Jeff Greenberg
    May 18, 2011 at 1:30 pm
    After you’ve setup compressor, click on the batch (not the individual video clip entry). The Inspector should show “Job Action.”
    Change your Output Device to Hard drive and you’ll get a disk image that you should be able to reuse.
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Ethan Young
    May 18, 2011 at 4:20 pm
    Thanks for tip! That’s a very helpful idea.
    Once I have the disk image saved what is the best method to replicate Blu-ray discs from it? I have an external BD burner attached via firewire, and I’m running the FCS suite. Does it require additional software like Encore or Toast?
  • Jeff Greenberg
    May 18, 2011 at 5:20 pm
    To be honest, I’m not sure. I figure if it’s a disc image, then Apple’s disk utility ought to be able to burn it for you. How about you try and let us know. 😀
    Best,
    Jeff G
  • Peter Dewit
    May 19, 2011 at 1:52 pm
    So you’re creating the file then dragging it into a disk image? If that’s the case you’re probably copying it as data rather than a BD. Typically you’d have to use authoring software of some type(encore Toast etc) to properly build a BD that players will recognize.
  • Ethan Young
    May 19, 2011 at 3:43 pm
    So with Toast you can revisit an old project file later and quickly burn a one-off BD disc without re-encoding? I wish there was a way to do that with FCS, it takes an overnight Compressor batch just to create a single disc, unlike DVD Studio Pro where you just open the project and swiftly format a new DVD. Maybe Final Cut X will have some better BD functionality.
  • Randolf Shanklemeyer
    August 18, 2011 at 5:52 pm
    I am trying the same workflow from compressor. I attempted to burn the BD disk with Toast 10 with the BD Plug-in. I was unable to join the video (H.264 for Blu Ray) AND audio (Dolby Audio.ac3) files. They play as separate files. Any way to join them or suggestions?
  • Ethan Young
    January 6, 2012 at 10:13 pm
    OK, I have figured out the best workflow for this. After I complete a FCPX project for a client I follow this workflow on my Mac:
    1. Export master file from FCPX
    2. Use Compressor to encode it for a DVD but choose DISK IMAGE (Hard Drive) in the JOB ACTION>OUTPUT DEVICE setting instead of burning a disc. This creates a disk image (.img) file that I can store to quickly burn extra discs in the future.
    3. Use compressor the same way for the Blu-ray version (create disk image)
    4. Use Toast 11 to burn the discs. Toast has a feature that allows you to create a disc directly from a disk image.
    I find this to be the easiest way to handle additional orders without needing to re-encode or anything.
  • Ben Gordon
    November 8, 2013 at 7:13 pm
    Hi Ethan, could you possibly elaborate on step 4 in the process you outline – the Toast 11 function to create discs form disk images?
    I’m trying to use this to burn consecutive Blu Ray discs and am having trouble finding that Toast feature.
    Thanks a million,
    Ben
    Macbook Pro 2.5 Ghz Intel Core 2 Duo
    2 GB 667 MHz DDR2 SDRAM
    OSX 10.5.8
  • Jeff Greenberg
    November 8, 2013 at 8:49 pm
    Change the Destination to Disk Image
    Best,
    Jeff I. Greenberg
    Author/Master Instructor/Speaker/Consulting
    My contact info and more
    New! Come see me speak @ NAB/Post Production World!
  • Luke Smith
    September 25, 2014 at 1:11 am
    Howdy. I’m still hoping to find out the answer to the original question. When you use the “Create a Blu-ray” destination in Compressor 4, it encodes the audio and video files, burns the disk, and leaves the encoded sources files behind. In my workflow, I just want to make an adjustment or two to the built-in menu options before I burn the disk again, all without having to re-encode the media files.
    I can’t help but wonder why it seems like Compressor can’t reuse them. Anyone?
    Thanks for the help, gents.
    Luke
