Activity › Forums › Apple Final Cut Pro Legacy › compressor broken
compressor broken
Posted by Jason Levy on October 5, 2008 at 5:00 pmCompressor question..
It appears to be broken.. I have a job cued that will not finish.. nothing’s happening and it goes on and on blocking the cue. Rebooting doesn’t help as it just starts up again on it’s own. Canceling does not help as it refuses to cancel.. Kind of a Frankenstein job. Anyone know where to go to delete the job cue manually?
thanks,
Jason
Jeremy Garchow replied 12 years, 2 months ago 6 Members · 10 Replies -
Jeremy Garchow
October 5, 2008 at 5:17 pmFirst, Quit everything so that only your finder is running.
Then in the finder hit command-shift-G and then type this in: /var/spool/qmaster
In the qmaster folder you will find a folder or two of very long file names. Delete them and emptyt the trash.
Then open up Compressor and clear your history and quit compressor.
Restart, then try again.
Jeremy
David Bogie
October 6, 2008 at 3:28 pmJeremy, I bow to your knowledge of Compressor and Qmaster’s finer points. But, man, you gotta admit, that is one totally obscure thing to to know let alone how to fix.
I’ll bet that’s not in the manual!bogiesan
Jeremy Garchow
October 10, 2008 at 7:34 pm[david bogie] “But, man, you gotta admit, that is one totally obscure thing to to know let alone how to fix. “
It is strange. I picked it up from an Apple article on how to reinstall Compressor.
Tom Early
September 16, 2009 at 4:59 pmOr you can just do the equivalent of quitting the process in Task Manager in Windows, and quit the process in Activity Monitor. I believe it may be listed within there by user name, beyond that it should be obvious. Somewhat more user-friendly, no?
Glen Pfeiffer
March 8, 2010 at 11:18 pmCompressor does this to me like every time I send something… the fix works for a day or so it seems, any idea how I could make it permanent? I dont like having to shut down every time I send a batch…
Jeremy Garchow
March 8, 2010 at 11:46 pmGlen, are you sending refernce movies or going straight to compressor. If you aren’t send ref movies you should.
Dallas Kruse
July 25, 2014 at 12:03 amWhat does this mean to “send ref movie to compressor”? I’ve been opening compressor and dragging my files in to transcode to ProRes 422. Am i doing this wrong?
Music Producer dabbling in Video.
FCP 7. CS3, 5. AE.
Canon T3i. -
Jeremy Garchow
July 25, 2014 at 2:52 amIt’s a reference movie, meaning do not click the make self contained box when exporting.
