Activity Forums Apple Final Cut Pro Legacy Compressor bogged down
  • Compressor bogged down
    Posted by Jim Carswell on November 3, 2009 at 1:34 am
    Hello all,
    I am attempting to use Compressor to create files for burning a DVD in DVD Studio Pro. I have created a QUICKTIME reference movie of my Pro Res 1920 x 1080 timeline. Added the file to Compressor, turned frame controls on and set the deinterlace filter to best and rate conversion to best.
    Right now, Compressor is telling me it will take 823 hours to complete the job.
    Any ideas as to what is slowing things down? Any solutions or help of any kind is appreciated.
    Jim
    Jim Carswell
    Spyhop Productions, Inc.
    Savannah, GA
    http://www.spyhopproductions.com
    Jim Carswell replied 16 years, 10 months ago 4 Members · 5 Replies
  • Aaron Neitz
    November 3, 2009 at 1:57 am
    why de-interlace and rate conversion?
    If you’re working in 23.98 HD then you can make a 23.98 .m2v file for DVD (this is ideal format for DVD). Or if you’re working in 1080i you can make a 29.97 file for DVD.
    Turn off Frame Controls and Compressor can spit out a 1080 feature film to DVD resolution lickety split.
  • Jason Brown
    November 3, 2009 at 1:58 am
    Just to make sure…you should be using 720×480 set to 16×9 anamorphic. 1920×1080 is just your source, right?
    The issue may be the QT ref…why aren’t you using File – Send to – Compressor? That is my workflow and it’s flawless.
    -Jason
  • Jim Carswell
    November 3, 2009 at 2:15 am
    I don’t know why I changed how I have made DVDs in the past. I had been doing so much reading here on the COW that I think I got myself incredibly confused. I thought I had read some where recently to turn frame controls on. Apparently that’s not the case.
    I attempted to go straight from my Pro Res 1920 x 1080 timeline to compressor with less than positive results. After more than 24 hours of Compressor working on the timeline I had nothing to show for it.
    So, I am now exporting a down converted QUICKTIME reference movie (DV 50 anamorphic) of the one hour timeline and will see how compressor reacts to it.
    Any more suggestions?
    Thanks for the help.
    Jim
    Jim Carswell
    Savannah, GA
  • Alex Elkins
    November 3, 2009 at 10:06 am
    [Jim Carswell] “I had read some where recently to turn frame controls on. Apparently that’s not the case.”
    Hi Jim,
    You would turn frame controls on and adjust to higher quality settings if you needed better results upscaling, converting timebase etc. For converting for DVD is itsn’t really necessary to do that if you’re not converting NTSC to PAL.
    [Jim Carswell] “I am now exporting a down converted QUICKTIME reference movie (DV 50 anamorphic) of the one hour timeline”
    Exporting as DV50 was an unnecessary step really. You can export the HD timeline as a reference file (make sure it’s rendered first) and then let Compressor do te job of converting to SD DVD. That’s what it’s there for.
    Good luck,
    Alex Elkins
    Salad Daze Films – Freshly Tossed
  • Jim Carswell
    November 3, 2009 at 3:24 pm
    Thanks to everyone who chimed in on my issues. I appreciate your help.
    As I indicated earlier I down converted the HD timeline to DV50 and ran it through Compressor and DVDSP and still wasn’t overly pleased. But at least I was able to burn a DVD.
    I than went back and exported from the HD timeline directly to Compressor again (for the sixth time). This time it worked successfully as it has in the past. The DVD that came from the HD timeline does look better than the down converted version. So will go with that as I make duplicates.
    Again, thanks for the help.
    Jim
    Jim Carswell
    Savannah, GA
