Activity Forums Apple Final Cut Pro Legacy Compressor batches never goes away
  • Compressor batches never goes away
    Posted by Sverker Hahn on February 11, 2009 at 6:00 pm
    When I try to cancel a job in the Batch Monitor, it just goes on “Cancelling…” forever, hour after hour. This makes it difficult to start other batches. Why can´t this stupid programme do as I tell it?
    Sverker Hahn, Stockholm
    Slower is better!
    Sony EX1
    Final Cut Studio 2
    iMac Intel
    MacBook Pro 15″
    Sverker Hahn replied 17 years, 6 months ago 3 Members · 3 Replies
  • Nicholas Bierzonski
    February 11, 2009 at 6:28 pm
    Select the item you want. Then click stop. Let it stop and then click delete.
    If you are following the above method and still have issues try trashing your Compressor preferences.
    -Nicholas Bierzonski
    Senior Editor/DVD Author/Java Boy
    http://www.finalfocusvideo.com
  • Lot Mallari
    February 11, 2009 at 8:24 pm
    Or the quickest way to do it is to reset background processing. Make sure batch monitor is close then go to compressor pull down menu and select reset background processing and click ok. Quit compressor and relaunch the app. 99% fix the problem.
    Lot Mallari
    The Cimarron Group
  • Sverker Hahn
    February 14, 2009 at 1:44 pm
    Thanks for the tip, Lot.
    It seems to work now.
    BTW, I had problems with DVD Studio Pro, where formatting failed without any reason. That one was solved by restarting the computer. I didn´t think that was supposed to be needed in OS X …
    Slower is better!
    Sony EX1
    Final Cut Studio 2
    iMac Intel
    MacBook Pro 15″
