Activity Forums Apple Final Cut Pro Legacy compressor audio filter fails
  • compressor audio filter fails
    Posted by Kyriakos Tacos on February 9, 2008 at 9:42 pm
    I’m trying to use Compressor 3 to add audio fade/in out filters on FCP6 exported clips (DV). When I use the unmodified default 300k h.264 web/streaming preset, the clip compresses fine. However, the job fails when I add the Audio Filter “Fade In/Out” with a duration of 1 for both in and out and gain at -100 for both.
    I’d prefer using the filters in compressor so that I don’t have to add transitions in FCP (The clips I’m working with are simple subclips that don’t require their own timeline).
    I’ve done all recent updates, rebooted, tried deleting compressor prefrences. No luck.
    Any suggestions?
    OS10.4.11
    FCS2
    Dual 2G, G5
    Kyriakos Tacos replied 18 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
