Activity Forums DVD Authoring Compressor and Format. This is probably an easy one!
  • Compressor and Format. This is probably an easy one!
    Posted by Cameron on June 1, 2005 at 4:07 pm
    When creating quicktime movies that will be used on a DVD what type of compressor should I specify?
    These are a few of them that are listed:
    Animation
    Cinepak
    DV-PAL
    DV/DVCPRO-NTSC
    DVCPRO-PAL
    Mpeg-4
    Sorenson 3 video
    and about 10 more…
    Also what is the best format?
    the options are:
    16 bit color
    24 bit color
    32 bit color
    etc.
    Thanks!!!!
    cameron
    Chris Borjis replied 21 years, 3 months ago 2 Members · 3 Replies
  • Chris Borjis
    June 1, 2005 at 4:24 pm
    none of those will work. You need the one that says mpeg2.
  • Cameron
    June 1, 2005 at 6:27 pm
    Can export my movie in After Effects to mpeg2?
    thanks!
  • Chris Borjis
    June 1, 2005 at 8:22 pm
    if you have 6.5 on the pc yes, I think you can.
    I don’t think the mac version supports mpeg2 output yet.
    You could export it as an ANIMATION file then compress
    that with an mpeg encoder software.
    Thats How I do all of my dvd menu’s.
    If you have apple compressor, it should have an mpeg2
    output module.
