Activity Forums Compression Techniques compressor and a dvd with bad motion flow
  • compressor and a dvd with bad motion flow
    Posted by Macmauro on March 2, 2006 at 10:15 pm
    Hi from Maurizio, italy, pal system
    i edited a video Final Cut 4
    it’s full of still images and then video clips
    on an original soundtrack
    i compressed it with compressor and made a dvd using dvd studio pro
    then the problem:
    at the beginning the sound follows
    images in the way it has to
    but during a sequence of very fast still images (1 for second)
    the music is on late, it start later then the video clip and goes on in this wrong way
    i can’t say it’s a lost of synchro
    cause at the end of the video
    the music return to be ok.
    i tried different compression setting (60 min. 90 min. 120 min. on dvd) and different motion estimation but i didn’t solve the problem
    is it a special case using rapid sequence of images and then
    normal frame rate for mpeg2 compression?
    what kind of setting i could try?
    any suggestions?
    thanks
    Maurizio
    Macmauro replied 20 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
