Activity › Forums › Apple Final Cut Pro Legacy › compressor and 16×9
  • compressor and 16×9
    Posted by Brad Kopp on December 16, 2009 at 3:28 pm
    I have FC 6.0..6 so I don’t have the template for you tube.. I want to use compressor to reduce a 6gig video for utube.. in the settings tab way down at bottom (custom settings) there is a 16×9 H 264 for high band width.. I used that setting but my video is coming out in a couple different sizes (squeezed down a little) and the quality is bad.. do I use the geometry tab set to crop to 16×9?
    I got one good conversion (a short test) which the codec says Linear PCM, H.264 but I cannot find that setting in inspector to redo it.
    Moto Guzzi rider
    dog lover w/wife, Ex & 3 kids
    Brad Kopp replied 16 years, 9 months ago 3 Members · 6 Replies
  • Chris Borjis
    December 16, 2009 at 5:06 pm
    I would suggest forcing a size of 864×480 then upload.
    youtube will recognize that as 16×9.
    at least its a work around to get it done.
  • Rob Grauert
    December 16, 2009 at 7:54 pm
    For Youtube I use 640X360 when using 16:9 video. That’s the size of the image on the site, so that’s why i use it.
    As for Settings, once you drop the h.264 preset onto your video, in the inspector:
    Go to Encoder Pane:
    Video settings: 30fps, set keyframes to automatic, and quality slider to High.
    Audio settings: Set format to ACC, Channels to Mono, Rate to 48KHz, Render quality to Better, and target bitrate to 128kbps.
    Frame Controls Pane:
    Click on the sprocket to turn on Frame Controls.
    Resize Filter: Better
    Output Fields: Progressive
    Deinterlace: Best
    Race Conversion: Better
    Geometry Pane:
    Dimensions: 640X360
    Pixel Aspect: Square
    If you shot interlaced footage, deinterlacing will take a long time. If you shot progressive, Compressor doesn’t have to deinterlace, so the encode won’t take very long.
    Robert J. Grauert, Jr.
    http://www.robgrauert.com
  • Brad Kopp
    December 16, 2009 at 8:00 pm
    thankyou both! I believe you have solved my stupidness, at least in this area..
    Moto Guzzi rider
  • Chris Borjis
    December 16, 2009 at 10:13 pm
    640×360 does work but I find sometimes that starting out
    larger will yield a better looking result….thats been my experience.
  • Rob Grauert
    December 17, 2009 at 12:18 pm
    Yea, you’re probably right, Chris. I just never had a problem with 640X360 ever since Youtube’s video quality became watch-able. Your logic definitely makes sense though.
  • Brad Kopp
    December 17, 2009 at 1:12 pm
    my compressor has been crunching for 17 hours and the render bar has moved about 1/5th of the bar.. this is going to take about 3 days to finish.. I’ll have to try something else and sacrifice quality for time. thanks, Brad
    Moto Guzzi rider
