Activity › Forums › Apple Final Cut Pro Legacy › Compressor anamorphic export HELP!
  • Compressor anamorphic export HELP!
    Posted by Micah Smith on February 21, 2010 at 10:48 pm
    I’m having trouble exporting footage from Compressor shot in 24p Advanced on a DVX in Squeeze mode. In the screenshots below, I have exported two different movs each with everything identical, h264, 6k bitrate, key every 120 frames, etc. except for the frame size and pixel aspect ratio (PAR).
    This one I encoded with a custom pixel frame size of 854×480 with a PAR of 1.00 or square. Notice the artifacting and in the blacks especially, but this is the frame that matches what I see in the Canvas in FCP the best.
    Next, this one is encoded in 720×480 with a PAR of 0.8438(or anamorphic) and has little or no artifacting in the blacks, but this frame looks horizontally stretched a little bit compared to my canvas in FCP. Note: quicktime compensates for the 720×480 frame and stretches it to 854×480 to display correctly on a LCD right?
    Basically I need help on what I’m doing wrong here, I want the cleanest image possible, so if that means a slightly stretched frame, then thats ok, but I’d like not to. Should I be exporting to 720×405 with a 1.00 PAR instead?
    Also, my setup is a Macbook Pro March 2009 with FCS 3 with all the latest updates. Any compression tips, advice would be much appreciated!
    Thanks in advance! 🙂
    Rafael Amador replied 16 years, 7 months ago 2 Members · 3 Replies
  • Rafael Amador
    February 22, 2010 at 5:54 am
    The first export is the correct one.
    Everything for the web or to be played in a computer must be done with square pixels.
    But why in the earth have you set K-frames every 120 frames?
    That makes no sense.
    Your picture with a data rate of 6 Mbps could have a K-frames every 6 frames or so.
    K-frames is what holds the quality in H264, MPEG-2, etc.
    Think that normal DVDs MPEG-2 set a K-frame every 12/15 frames.
    So put the K-frames in Auto and export again.
    rafael
    http://www.nagavideo.com
  • Micah Smith
    February 22, 2010 at 11:46 pm
    Apple’s site says, “…have one key frame every 5 seconds (multiply the frames per second by 5)” so I took 24fps and multiplied by 5 with gives me 120. Is this wrong?
    Read it here at section (c.)
    https://www.apple.com/quicktime/tutorials/h264.html
    Also, should I keep the PAR set at square no matter what even though quicktime will compensate for this? And if I do, what resolution should I set it at? 720×405 or 854×480?
  • Rafael Amador
    February 23, 2010 at 2:18 am
    And just below they write:
    “For H.264, we recommend leaving the key frame interval up to the compressor; so you should choose “Automatic” for the best quality result”.
    [Micah Smith] “Also, should I keep the PAR set at square no matter what even though quicktime will compensate for this? And if I do, what resolution should I set it at? 720×405 or 854×480?”
    QT is compensating in this case, but many times doesn’t.
    If you want your clip display well everywhere, don’t take risks and use Square pixels.
    Any of both sizes are OK
    864×486 would be better than 854xx480.
    Rafael
