  • Posted by Joseph Dobek on January 3, 2008 at 12:51 pm
    This is a new problem for us. We can no longer export out of FCP into Compressor. While in FCP 6.0.2 we go to File > Export > Using Compressor and it activates Compressor but it no longer dumps the Sequence into Compressor.
    G5
    OS – 10.4.11
    Final Cut Studio 2
    Compressor 3.0
    Thanx – J
    Urban Potocnik replied 18 years, 7 months ago 5 Members · 11 Replies
  • 11 Replies
  • Walter Biscardi
    January 3, 2008 at 12:55 pm
    Then export a Reference Quicktime movie of your Sequence.
    Bring that into Compressor.
    This is actually the only way I work with Compressor as this is a faster way to encode. Compressor runs slower when FCP is also running in the background so I never use “Send to Compressor” within FCP.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Joseph Dobek
    January 3, 2008 at 2:33 pm
    Overall Compressor is just not working for me. I am unable to set up a New Batch. When I select New Batch in the File Menu it does not respond. When I try to open Compressor on it’s own it will only goes as far as the start-up box with the icon.
    I’m wondering if this is my system and I need to re-install Final Cut Studio 2 or is it because of the OS (10.4.11)
  • Walter Biscardi
    January 3, 2008 at 6:01 pm
    [Jay Dobek] “Overall Compressor is just not working for me. I am unable to set up a New Batch. When I select New Batch in the File Menu it does not respond. When I try to open Compressor on it’s own it will only goes as far as the start-up box with the icon.
    I’m wondering if this is my system and I need to re-install Final Cut Studio 2 or is it because of the OS (10.4.11)”
    We have three systems all running Studio 2, latest updates and Compressor is not an issue here. Really don’t know what to suggest. I simply launch Compressor, drag the quicktime files in, drag the Settings on the clips and hit Submit and walk away.
    Read my Blog!
  • Mike Daniels
    January 3, 2008 at 6:11 pm
    We have had similar problems, and our IT dept usually just empties the Cache for compressor and then it works fine, try that.
    Mike Daniels
    1st Assistant Editor
    VICE Films/VBS.TV
    https://www.vbs.tv
    https://www.myspace.com/vbstv
    https://www.youtube.com/vbstv
  • Jeremy Garchow
    January 3, 2008 at 7:35 pm
  • Joseph Dobek
    January 3, 2008 at 8:41 pm
    Thanks, I found this article as well. I’m re-installing Compressor right now.
  • Jeremy Garchow
    January 3, 2008 at 8:59 pm
    Make SURE you install and update Motion as well.
    Jeremy
  • Joseph Dobek
    January 4, 2008 at 3:40 am
    I followed Apple’s instructions on re-installing Compressor and I am still experiencing the same problems.
    I am unable to open Compressor – all I receive is the first screen with the Icon and program name (it never progresses further). If I try to open it via FCP I am unable to call up the Batch Window. So I can not drag files to the window, since there is no window.
    I’m wondering if I should re-install the whole Studio?
    Any ideas are welcome.
    Thanx – J
  • Jeremy Garchow
    January 4, 2008 at 3:45 am
    Did you run the software update after the install?
  • Joseph Dobek
    January 4, 2008 at 12:26 pm
    Immediately after, then restarted the machine.
