Activity Forums Compression Techniques Compressor, 720×540 16×9
  • Compressor, 720×540 16×9
    Posted by Geralyn Abinader on July 3, 2009 at 9:34 pm
    Hi, I have an animation with audio I need to export as an MPEG 2 (for a Roku playback device). The AV folks are requesting 720×540 16×9. I have created custom settings in Compressor and the files keep coming out at 720 x 404. What’s the deal? I can’t seem to get the setting I need.
    When I try do create a custom setting from scratch instead of by copying and changing an existing setting, I can’t seem to add audio to it, it’s video only.
    The original animation is 1280 x 720, square pixles.
    I have exported from Final Cut directly into Compressor and exported movies from After Effects (output with animation) and then go to Compressor. This doesn’t seem to make a difference. I’ve changed the sequence settings in FCP to DV and the comp settings in AFX to various settings, but really the issue seems to be with Compressor.
    Geralyn
    Geralyn Abinader replied 17 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
