  • Jerry Hofmann
    June 14, 2007 at 1:01 am
    Open the Preferences in DVD SP. Set up the compression settings from the encoding button.
    Jerry
  • 13 Create COW Profile Image
    13
    June 14, 2007 at 5:32 am
    you should use the compressor application it will give you better control then letting DVD SP do the compressing.
    There are plenty of posts on the DVD SP forum about setting, a quick search will give you lots of info.
