Activity Forums Apple Final Cut Pro Compressor 4.2.1 chose disk to export to
  • Compressor 4.2.1 chose disk to export to
    Posted by Claude Lyneis on November 28, 2015 at 6:58 pm
    Somehow the interface on Compressor 4.2.1 is too slick for me. I want to send the output to another drive, but can’t find how to set the destination. It is simple in earlier versions, but I am missing a click somewhere. Normally it just goes to my Movie file.
    John Rofrano replied 10 years, 9 months ago 2 Members · 3 Replies
  • John Rofrano
    November 28, 2015 at 7:33 pm
    [Claude Lyneis] “I want to send the output to another drive, but can’t find how to set the destination. “
    When you’re adding an Output, dropdown the Location options and select Other… then navigate to the location you want to save the output to.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Claude Lyneis
    November 28, 2015 at 8:26 pm
    Thanks. Since I normally dragged in some setting from the left side of the window instead of hitting the plus sign under the file sent in from FCPX, I didn’t have the grey box come up. Once I hit the plus, it works. Sometimes Apple interfaces are just to clean.
  • John Rofrano
    November 28, 2015 at 8:28 pm
    Yea, it’s odd that it has different behavior depending on whether you are using drag and drop or not but I guess it’s better if you want to have a group of files go to the same location to not have a dialog pop up with every file that you drop.
    Glad I could help.
    ~jr
