Activity › Forums › Apple Final Cut Pro › Compressor 4.1 error when using shared computers
Posted by Thomas Frank on January 16, 2014 at 3:16 pmHi,
I installed the latest Compressor which I really like except for one…
If I use the Process on: “shared computers” I get the error Failed 3x or Failed 4x on all process.
What does this mean and how can if be fixed?Warwick Teale replied 12 years, 8 months ago 3 Members · 3 Replies -
Loren Risker
January 16, 2014 at 6:55 pmDo all shared computers have read write access to the same folder where the batches go?
OutOfFocus.TV – Original series, music videos, mini-docs. -
Thomas Frank
January 17, 2014 at 11:46 amOkay, I created a Shared Folder and it worked for one try but on another I received the following error:
HOST [MAC Pro 7] Error: error from MovieExportFromProceduresToDataRef: error from MovieExportFromProceduresToDataRef: : 10006
and
error: mkdir failed for path = [/Users/Shared/Library/Application Support/Compressor/Storage/D8220947-D02E6012/shared
and
Finishing: 3x HOST [Mac Pro 4} Source subexport mount failed: host = Mac-Pro-1.local, path = /Volumes/FCP Raid/…
Also noticed that I don’t get any data in the Network Encoding Monitor
Warwick Teale
January 21, 2014 at 12:33 pmHi Tom ,regarding the error you see, (error: mkdir failed for path = [/Users/Shared/Library/Application Support/Compressor/Storage/D8220947-D02E6012/shared), just a couple of things you look at:
1. if you are runoff OS server, make confirm the path is shared with access to you r/w (.. it usually is
2. is this cluster storage has been removed previously, itMAY still have similar directory in the .Trash directory. ou may need to remove both of these .If 2. is true, then
a. stop sharing (don’t share computer in Compressor.app 4.1 prefs
b. delete the all the structures (folders) in /Users/Shared/Library/Application Support/Compressor/Storage / directory
c. attempt to empty the trash on your files systems. (cmd+shift+delete)
d. OPTONALLY: if the Trash won’t empty it may be because the serialisation needed to delete the objects in B. is not being honoured. Try to “rm -rf ~/.Trash” contents. If that fails you may need t restart th MAC to resolve the issue d. . The attempt steps c. and d. againA few people have had this issue.
It may help you
warwick
Hong Kong
