Activity › Forums › Apple Final Cut Pro Legacy › compressor
compressor
Posted by Arty Gold on July 14, 2006 at 10:29 ami did all my research and searches on the cow…
but i can’t seem to find anything on this…
i am trying to go from fcp 4.5–with my project thru compressor 2
so i can get it into dvd sp 4ok the video i have is one hour and 58 minutes
so i choose mpeg2 fast encode 120 then i changed the bitrate until it said i could get 160 minutes on a dvd-5
is the right way to handle this ?
or am i way off before i start the 6 hour compressing ?thanks
John Fishbackreplied 20 years, 2 months ago 4 Members · 7 Replies
David Roth weiss
July 14, 2006 at 2:59 pmArty,
Six hours sounds like a very long time — in my 2.3ghz G5 an 85-min. project takes only 50-mins to encode to MPEG-2 using Compressor. Is your MAC an older slower G4? Are you exporting directly from the timeline? If the answer to the later question is yes, don’t do that, export from the timeline first either to a reference or self-contained movie, then encode using Compressor. This will save you considerable time. Also, the 2-pass encoding was broken and still may be, you should pobably change the prest to one pass before starting your encode. The results are still very good, sometimes better even than the best 2-pass depending on tghe material, and that wil also save time.
DRW
Chris Babbitt
July 14, 2006 at 5:04 pmDavid,
I recently upgraded to 5.1 and just tried Compressor 2-pass to encode a 2:17 program. It appears that all the issues I was having with 2-Pass have been resolved. This confirms what I was told by an Apple Rep at NAB. As soon as I have a chance to view the entire DVD, I will post the results.
David Roth weiss
July 14, 2006 at 5:19 pmThat’s good to know Chris, I am using 5.1.1 now and was kind of hoping that was one of the things that had been fixed.
Chris Babbitt
July 14, 2006 at 5:31 pmSo far, the extraordinarily long encode times, huge file sizes, and cut-off endings, all issues that I was consistently experiencing before, are all gone. As far as image and motion quality are concerned, I will know better after I view the DVD. But, most definately, they have fixed some things.
Chris Babbitt
July 15, 2006 at 5:24 amI viewed the DVD. Everything seems to be ok. Just like it was in Compressor 1.0.
Arty Gold
July 15, 2006 at 11:50 amthanks !
yes i was using compressor right from the time line…
i’m going to try it the other way now…
i’ll let you know how it goes -
John Fishback
July 16, 2006 at 9:47 pmIf you’re doing any cropping or filtering, that can affect the encoding time.
John
Dual 2.5 G5 4 gigs RAM OS 10.4.3 QT7.0.3
Dual Cinema 23 Radeon 9800
FCP Studio 5 (FCP5.0.4, DVDSP4.0.2, Comp2.0.1, STP1.0.2)
Huge U-320R 1TB Raid 3 firmware ENG15.BIN
ATTO UL4D driver 3.50
AJA IO driver 2.1 firmware v23-28
SonicStudio HD DAW, Yamaha DM1000, Genelec Monitors
