Activity Forums Apple Final Cut Pro Compressor 4 Speed Question
  • Compressor 4 Speed Question
    Posted by Michael Harrington on August 31, 2011 at 11:53 am
    I have hundreds of GoPro clips I need to batch export with in/out points and using Compressor 3 to convert to ProRes, of course Compressor 3 is clunky and slow. I don’t necessarily mind the processing time but the interface reacting very slow to keyboard commands or when dropping on settings.
    I’m considering purchasing FCPX and/or Compressor just to handle converting hundreds of GoPro clips so I can batch with in/out points. Then plan to give them a go once I complete this huge project.
    Can anyone tell me if indeed Compressor 4 is faster, more responsive and does the interface work much the same as 3? Do to looming deadlines I don/t have much time to learn new software.
    Michael Harrington
    Mac Pro, Dual Quad-Core Intel Xeon 2.66 GHz, 12 GB, FCP7, Snow Leopard, ATI Radeon HD 4870, 30-inch Cine Display, 4 – 1TB internal, G Speed 6TB Raid 5, 1.25TB Esata, Numerous FW 800 external drives, Matrox MX02Max, FSI 17″ Broadcast Monitor, Black Magic Mini Sync Generator, Mackie 1402 & Event 20/20 monitors.
    Matthew Celia replied 15 years ago 3 Members · 2 Replies
  • Lawrence Eaton
    August 31, 2011 at 2:40 pm
    Michael,
    I use Compressor 4 and my GoPro and have found that Compressor 4 is more efficient in the set up and use of multiple cores/ clusters etc.
    The UI is much the same as Compressor 3 – which could be a good point or not, depending on how you are sitting on your chair.
    The integration between FCP X and Compressor 4 is better – though that is a personal comment.
    Ingestion of GoPro mp4 into FCP X goes smoothly and without a hiccup, in my experience.
    That’s all I can say as I’ve never had to think about it, personally.
    Regards,
    Lawrence
  • Matthew Celia
    August 31, 2011 at 4:27 pm
    I found no real speed difference in my tests. In fact, Compressor 4 seemed buggier to me.
    If you have access to it, Adobe Media Encoder flies through that stuff rather quickly, being 64-bit. Otherwise, you can set up a quick cluster in Compressor 3 and probably get the same performance.
    FCP Guru
    http://www.fcpguru.com
