Activity Forums Compression Techniques Compressor 4
  • Compressor 4
    Posted by Chuck Obernesser on February 12, 2012 at 6:12 pm
    I posted this as well on apple’s compressor support. Nothing has worked so far and I need it so I can export a show out as an MPEG 2 file from FCP 7
    I just bought compressor 4. I am running on a Mac Pro 8 core (early 2009) 2.26 GHZ with 6 GB or ram.( I know I need more ram) I am on the trial version of FCP X but I have FCP 7 on my main hard drive. I have installed, uninstalled, I have three drives so i dropped compressor into a different drive I have searched all over google and nothing is helping. When I open C4, I get a window on start up that asks me if I want to make a blu-ray, you tube video, etc… I choose one of the following (tried them all) and once I do that window disappears, but nothing else happens. It just sits there, I left the program running for 5 mins and still nothing would appear. I put C4 on the task bar and dropped a video clip on it to see if it would open the UI that way but still nothing. I read from apple about two different ways to try to fix. One was to partition the drive and the other was to update everything then try again. I really do not want to partition the drive because of the chance i could lose something. The other option mentions opening motion then closing before doing anything else. I don’t have motion on this machine. I am using FCP X trial version and that is running and working ok. Any have any ideas on how to get Compressor working?
    Jeff Greenberg replied 14 years, 6 months ago 2 Members · 1 Reply
  • Jeff Greenberg
    February 27, 2012 at 10:03 pm
    First, Move all the FCP7 pieces into your Application directory.
    Move all the FCPX pieces into a folder called FCPX in your Application directory.
    That’s exactly what the tech note tells you to do.
    Then run Motion 4 and then Motion 5.
    At this point everything has been correctly ‘registered’ with the OS.
    To test compressor 4: open it. Cancel the templates…and then drag a piece of video in, pick a preset and choose “Submit”
    Let us know how that goes. Should take 10 min or so.
    Best,
    Jeff G
    Certified Master Trainer | Adobe, Apple, Avid
    You should follow me (filmgeek) on twitter. I promise to be nice.
    My book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
    Lynda.com – Compressor Essentials 3.5 and 4
    Contact me through my Website
