Activity › Forums › Apple Final Cut Pro Legacy › Compressor 3.5.3 stating wrong native field dominance for DVCPro HD 1080i60 clips
  • Compressor 3.5.3 stating wrong native field dominance for DVCPro HD 1080i60 clips
    Posted by Mike Konstan on October 7, 2010 at 12:02 am
    Here’s a weird issue we encountered today…
    I needed to convert DVCPro HD 1080i60 clips to ProRes 422 1920×1080. When I first attempted a conversion of a test clip prior to running the full batch, I found that the clip was having some difficulty playing back correctly in a ProRes 422 1920×1080 sequence in FCP — it was getting the green realtime playback bar, but when I rendered the clip, it appeared the fields were shifted on playback.
    I checked my interlace settings in the ProRes 422 compressor setting, and they were correctly set for Upper Field First. But still the resulting clip still was not playing back smoothly.
    Final Cut Pro identified the clips as having a field dominance of Upper Field First in the browser. However, when I checked the clip via Compressor 3.5.3’s A/V Attributes Inspector panel, it incorrectly reported that the Native Field Dominance for each of those same clips were Bottom First!
    Then I manually changed the Native Field Dominance in Compressor to what I thought it should be for HD– Top First. I added my ProRes422 setting and tried it again in FCP. The resulting clip played back perfectly!
    So, despite having to manually change each individual clip’s Native Field Dominance setting in Compressor prior to applying my ProRes setting and running the batch, ultimately the clips all played back correctly in FCP.
    Mike Konstan
    MAK Digital Media, Inc.
    Orlando, Florida
    Chad Tingle replied 15 years, 11 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    October 7, 2010 at 3:34 am
    Yes. I have seen compressor guess wrong like that before. Good catch.
  • Mike Konstan
    October 7, 2010 at 3:42 am
    Thanks– it wasn’t so bad once I figured out the workaround. The downside is having to change the native field dominance on each clip one at a time…
  • Chad Tingle
    October 7, 2010 at 6:18 pm
    appreciate the heads up sir
    Chad Tingle
    Producer/Editor
