Activity › Forums › Apple Final Cut Pro Legacy › Compressor 3.5 still hangs. Sad.
Jeremy Garchow replied 13 years, 6 months ago 8 Members · 20 Replies
Alexander Kallas
September 2, 2009 at 8:07 amErik,
In your first post you show Tiger as your OS, with Studio2
Then in subsequent posts, it’s Snow Leopard with Studio3.
AFAIK Studio2 does better on Leopard
Did you do a clean install or an overwrite from Tiger to Snow Leopard?Cheers
Alexander -
Chris Borjis
September 2, 2009 at 7:40 pm[Jeremy Garchow] “you have to make sure that you select your cluster after hitting submit but before hitting submit again”
I wish you could set it to default to the cluster.
Jeremy Garchow
September 2, 2009 at 7:45 pmI just looked for that option yesterday. I imagine that it’s not there as the clusters can get deleted and changed….my speculation anyway.
Jeremy
Trig Simon
September 22, 2009 at 1:48 amHow can I reinstall Compressor? Do I have to reinstall the whole FCsuite3?
Jeremy Garchow
September 22, 2009 at 3:10 pm[Trig Simon] “Do I have to reinstall the whole FCsuite3?”
Kind of, You have to reinstall just the applications, not all the media. A reinstall of just the apps is very quick. Click the ‘Custom’ button.
You can also check COmpressor Repair from Digital Rebellion.
Jeremy
Jet Kaiser
October 9, 2009 at 5:47 pmHello, I have/had this issue as well.
If I hit cancel on a transcode, all it would do is hang and the time remaining would climb and climb, sometimes 15 hours our more.There is no way (that I’ve found) to recover from this. I just click the problem transcode, highlight it and hit “delete”. I goes away instantly. Then you just try it all over again (from FC).
Jeremy Garchow
October 9, 2009 at 7:10 pm[Jet Kaiser] “If I hit cancel on a transcode, all it would do is hang and the time remaining would climb and climb, sometimes 15 hours our more. “
GO to the compressor menu and hit “reset background processing” and choose the option to cancel the jobs.
Elijah Lynn
November 12, 2009 at 9:35 pm“Also, there’s a ‘reset background process’ function in the ‘Compressor’ menu that helps to clear things up.”
You da man Jeremy!! Worked perfectly (after 30 minutes of stuck-ness)
Murray Louw
April 1, 2013 at 3:52 pmMy word! That seems to work! Been about 3 & half years since your post & it’s helping me now. Thank you J!
Jeremy Garchow
April 1, 2013 at 4:18 pm[Murray Louw] “Been about 3 & half years since your post & it’s helping me now. Thank you J!”
Glad you found this old thread!
Jeremy
