Activity Forums Compression Techniques Compressor 3.5 Default Settings NOT TAKING!
  • Compressor 3.5 Default Settings NOT TAKING!
    Posted by Nathan Tinsley on August 11, 2010 at 7:37 pm
    I’ve been using Compressor for about a year now and I love using the preferences to set up a default setting and destination for my exports. So now I’ve upgraded to FCS3 and Compressor 3.5. I set up my preferences the same way…. only it doesn’t work! I’ve checked it several times, made several different selections and yet when I to a SEND TO — COMPRESSOR, the timeline shows up in the batch window with NO DEFAULT settings on it. I looked at the other check boxes in the preferences dialog but none seem to help. What am I doing wrong?
    Ron Beyers replied 12 years, 1 month ago 5 Members · 4 Replies
  • Karen Schwarzer
    August 11, 2010 at 8:46 pm
    A note here – I work with Nathan and If we import a file into Compressor – then the default setting appears. But if we “send to” compressor from FCP 7 the setting doesn’t appear.
  • Tony Florio
    May 16, 2011 at 8:19 pm
    Wow, my exact problem, yet no solutions posted for it in several months. Darn, I wish someone knew how to fix this! It worked before and it’s a HUGE pain in the butt, and worse, the view windows for “SETTINGS/DESTINATION” doesn’t stay open either, making if MORE steps to do this procedure.
  • Craig Seeman
    May 16, 2011 at 8:38 pm
    So many people have found Send to Compressor unreliable. You could try tossing your preferences. You could hope that with FCPX Apple has found a better way.
  • Ron Beyers
    August 5, 2014 at 1:58 am
    3 years after the last post, and still the problem persists. Hoping it’s solved when using FCPX.
