Activity Forums Apple Final Cut Pro Legacy Compressor 3.5 and less than stellar render times
  • Compressor 3.5 and less than stellar render times
    Posted by Graham Hutchins on August 28, 2009 at 7:27 am
    Hello all,
    I was just curios and wanted to get a feel for everyone else’s experience.
    I recently upgraded to FC Studio 3 and with it, Compressor 3.5. I’m running a 2.26 GHz eight core, 6 GB of RAM and have the Qmaster configured for distributed renders with 16 threads.
    I’m getting really spotty processor load; anywhere from 15%-20% and then it will jump to 40%-50% and then will hum along at 96% for a bit before dropping down to 20%.
    This most certainly slows down render times. Before, with Compressor 3.0, it would take a dozen or so seconds to load the clip after you hit submit, but then it would kick into high gear and stay at pretty much full load until the render was finished. What I’m experiencing now doesn’t hold a candle to it and as much as I love waiting on computers, I’d like to know if there are any tweaks I can be doing or if anyone else is experiencing the same thing.
    Thank you for you time.
    -Graham
    OSX 10.5.6
    AE CS4, Nuke 5.1.3
    FC Studio 2
    Octo 2.26GB MacPro, 6 GB RAM
    Graham Hutchins replied 17 years, 1 month ago 5 Members · 7 Replies
  • 7 Replies
  • Scott Sheriff
    August 28, 2009 at 8:45 am
    I wonder if Snow Leopard in combination with FCS3 will fix this?
    It’s coming out today.
  • Graham Hutchins
    August 28, 2009 at 8:47 am
    I was hoping the same thing, although I don’t have any reason to believe it would. I forgot to mention that I’m also on 10.5.7, if that matters.
    Are you experiencing slower render times as well?
    -Graham
    OSX 10.5.6
    AE CS4, Nuke 5.1.3
    FC Studio 2
  • Ben Holmes
    August 28, 2009 at 9:24 am
    I would suggest doubling your RAM to 12Gb, as it’s generally advisable to have more than 1Gb per core. Although I have no idea why the newer version is less efficient at utilising what you have, the amount of memory allocated per core or thread is relevant in most distributed processing.
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
  • Graham Hutchins
    August 28, 2009 at 9:31 am
    Yup, couldn’t agree more.
    I hit the wall big time exporting a pretty complex comp out of After Effects about a week ago, but as you’ve noted, and in my experience with the previous version, I wasn’t having this issue.
    Perhaps the length of the thing may have something to do with it. Most of the stuff I transcode is usually less than 5 minutes, whereas the project I’m currently working on (color on a feature) has clips in 15-20 minute chunks.
    It still feels like even for longer stuff, 3.0 just stayed full tilt the whole render where now, it’s all over the place.
    Hmmm.
    -Graham
    OSX 10.5.6
    AE CS4, Nuke 5.1.3
    FC Studio 2
  • David Roth weiss
    August 28, 2009 at 10:37 am
    [Graham Hutchins] “I recently upgraded to FC Studio 3 and with it, Compressor 3.5. I’m running a 2.26 GHz eight core, 6 GB of RAM and have the Qmaster configured for distributed renders with 16 threads. “
    How did you perform the upgrade? Did you do a clean install, or upgrade over the top of FCS2? If it was the latter, that could easily account for any issues.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Shane Ross
    August 28, 2009 at 7:19 pm
    Have you turned on QMaster to take advantage of all your processors? if so, you need to change the “Cluster Options” pop-up in Compressor Preferences to “Never copy source to cluster.” That NEW feature is to make sure that all computers on the cluster have access to the media (if you use Reference Movies) and compressor will COPY all of the assets to a central location, THEN start compressing.
    annoying.
    Shane
  • Graham Hutchins
    August 28, 2009 at 8:41 pm
    Yup, Qmaster is set up and I did the “Never copy source to cluster” pref setting after seeing your post on the Apple forums.
    I think David might have nailed it though. I haven’t had the chance to do a fresh OS install before upgrading, so that might be the cause of the issue I’m having. I just need to get this latest project knocked out and then I’ll take my half day to backup and wipe my hard drive and do a proper clean install.
    Thanks for your response.
    -Graham
    OSX 10.5.7
    AE CS4, Nuke 5.1.3
    FC Studio 3
