Activity Forums Apple Final Cut Pro Legacy Compressor 3
  • Posted by Sanjay Chalisey on June 5, 2007 at 8:07 am
    Hi All,
    I have just installed Final Cut Studio 2 (upgrade) and now I’m encountering problems using Compressor 3.
    In short, each time I submit a job(with either a preset or a setting of my own) the following message appears:
    ‘Failed: 3 x INVOKING…’
    I have no idea what this means and haven’t a clue as to a solution!
    Would appreciate any help.
    Thanks very much in advance.
    Phil Muri replied 19 years, 3 months ago 4 Members · 7 Replies
  • 7 Replies
  • Jerry Hofmann
    June 6, 2007 at 3:22 am
    Sounds like an install problem… might try trashing the plist for Compressor… if this fails, I’d reinstall it.
    If you did a clean install of the upgrade, I’ll wager this goes away too… (i.e. it’s not happening here after a totally clean install of OS et all…)
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • David Jahns
    June 7, 2007 at 8:16 pm
    Any luck? I’m getting the same error.
    I will try to re-install…
  • Sanjay Chalisey
    June 8, 2007 at 8:11 am
    I’ve been advised to do a complete reinstall.
    So, trying this now – so fustrating!
  • David Jahns
    June 8, 2007 at 4:28 pm
    I re-installed FCS2, but it didn’t help.
    Interestingly, if I create a new user account, Comp3 works fine for that user.
    So – you would think I must have a corrupt preference file or soemthing right? I trashed everything I could find in my User folder – preferences, custom presets, etc… but nothing helped.
    Apple Pro Apps Support is looking into it and says they will get back to me by Monday.
    Luckily, I have Squeeze to fall back on – but the workflow isn’t as smooth.
  • Phil Muri
    June 12, 2007 at 5:42 pm
    David or sanjchal,
    Any success?
    I also have the said issue with Compressor 3 and Batch Monitor? Everything I submitted failed.
    I used FCS 2 upgrade and didn’t opt for a ‘clean-install’.
    I deleted Compressor 3 and Apple QMaster and now I want to re-install these items
  • David Jahns
    June 12, 2007 at 5:47 pm
    Sorry – no success as of yet.
    I’m still waiting on an answer from Apple Pro Video Support.
    I’m 99% sure a clean OS install and a clean FCP6 install would do it – but who has time for that, right?
    Luckily, I have Squeeze, which I’m using in the meantime…
  • Phil Muri
    June 12, 2007 at 10:26 pm
    Hi David,
    I called Apple Support and they had no idea
