Activity Forums Compression Techniques Compressor
  • Posted by Jesse Austin on April 28, 2011 at 6:35 am
    Hey All,
    Question, I am using FCP’s Compressor for this SD anamorphic job that I just completed with the edit. The final end will be YouTube, I have exported (from FCP) a uncompressed 8bit file of the project and have been attempting compression in Compressor with out any luck at all.
    When I bring the file into Compressor it keeps exporting it as 4×3 in stead of 16×9 anamorphic. I know that the original uncompressed 8bit file that is being used is in the correct format (853×480)…
    What am I doing wrong???
    Thanks for any help.
    Jess
    Jeff Greenberg replied 15 years, 5 months ago 2 Members · 1 Reply
  • Jeff Greenberg
    April 28, 2011 at 1:43 pm
    Actually, I’m willing to bet that the original file is 720×480 but being displayed at 853×480.
    When you get your video into compressor, go to the geometry tab.
    It should detect that the frame size is 720×480 and has a pixel aspect ratio of 1.2
    IF NOT, from the drop down for Frame size, choose CUSTOM and change the pixel aspect to NTSC CCIR 601/DV 16:)
    Try and and let’s find out if it worked!
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
