Activity Forums Compression Techniques Compressor 2.3 Encoding problems
  • Compressor 2.3 Encoding problems
    Posted by Mark David spencer on November 3, 2006 at 12:54 am
    Does anybody know if the problem with the Two-pass VBR compression in Compressor has been fixed?
    I read that 2.3 fixed the blocky 2-pass compression, but my experience tells me otherwise.
    I am editing skateboard videos (high motion) and I am stuck using 1 pass VBR because the 2-pass looks worse. I am out of ideas on how to make my video look better for action sports.
    Also, what is the advantage of using a smaller GOP structure, I hear that’s better but I seem to get worse video using IP with 6 or 15 than with IBBP with 15…
    Any suggestions???
    Ed Dooley replied 19 years, 10 months ago 2 Members · 3 Replies
  • Ed Dooley
    November 3, 2006 at 4:49 am
    I guess I would ask why you want to use VBR. How long are your videos? If they’re short enough to
    fit on a DVD without VBR, why not use a relatively high, but still within specs, CBR? There have been discussions
    about VBR producing better encodes, but I think that encoders these days, in general, if your video is short enough to fit on a DVD
    without needing to go to VBR, a CBR encode will look great. Hollywood goes VBR for 2 hour movie encodes,
    but is your skateboard video 2 hours?
    Ed
    [markambition] “Does anybody know if the problem with the Two-pass VBR compression in Compressor has been fixed?
    Any suggestions??”
  • Mark David spencer
    November 3, 2006 at 6:31 am
    I guess I don’t know what bitrate I need to set it at to get the results I need with the ridiculous level of motion in the program. I have about an hour and fifteen minutes of total material (including extras) and I have tried a CBR at 7.5 but I still seem to find artifacts in it…
    I have a dream…that all media production is 5% technical/95% creativity and not the other way around.
  • Ed Dooley
    November 3, 2006 at 5:16 pm
    This could help with bit-rate settings:
    https://dvd-hq.info/Calculator.html
    This discussion has specifics about settings for footage with motion, to help reduce artifacts (it’s for U-Lead,
    but there is helpful information about GOPs):
    https://phpbb.ulead.com.tw/EN/viewtopic.php?t=10880&sid=f0294fddc59740ba742a7c96fb1043ec
    Ed
