Activity Forums Apple Final Cut Pro Legacy Compressor 2 Standards Conversion
  • Compressor 2 Standards Conversion
    Posted by Stuart Simpson on June 23, 2005 at 1:17 pm
    So it’s been a wee while now since this came out… Anybody out there had a chance to try it and compare with other solutions yet?
    We’re using the nattress filter for this at the moment, I’d be interested to see how they compare.
    -Simmie
    1 G5 – Cinewave
    5 G4s – Cinewave
    1 xbox, 1 PS2 & a Gamecube
    https://www.speak.co.uk
    Stuart Simpson replied 21 years, 3 months ago 3 Members · 4 Replies
  • Graeme Nattress
    June 23, 2005 at 1:27 pm
    I converted a small, 8 second clip via my conversion from NTSC to PAL and via compressor 2. In C2, that small clip took 35 minutes to render, for just a plain DV NTSC to PAL conversion. The quality was great, but still introduced the motion blur that a full optical flow simulation should not, so I don’t know exactly what they’re doing in there, other than it’s as slow as hell. My conversion took just 1 minute, and that’s on a Dual 2ghz G5, so you can see that C2 is very slow indeed.
    Then I dropped the quality settings, and started getting unnacceptable conversions from C2. I’d get alternatiing frames of blurry and sharp when I lowered the de-interlace quality, and I’d get strobey motion on lowering the temporal quality.
    Overall, I’d say to Apple, 10 points for quality, but -100 for speed.
    Graeme
    http://www.nattress.com – Film Effects and Standards Conversion for FCP
  • Tunaking
    June 23, 2005 at 7:50 pm
    Did a pretty decent NTSC to PAL conversion. You need to futz with the frame conversion settings to get the quality (don’t use the preset). Graeme is correct, it is pretty slow. Definitely helps if you can cluster render it.
  • Tunaking
  • Stuart Simpson
    June 24, 2005 at 10:17 am
    Thanks for the thoughts guys. I’m perfectly willing to wait paitently for a conversion if it gets rid of the blur, but not if there’s no advantage over Graeme’s filter then my response is “meh.”
    Anybody done any direct compressor 1 vs compressor 2 comparisons yet?
    -Simmie
    1 G5 – Cinewave
    5 G4s – Cinewave
