Activity Forums Apple Final Cut Pro Legacy Compressor 2 mpeg1 16:9
  • Compressor 2 mpeg1 16:9
    Posted by Neil Ryan on July 15, 2005 at 2:28 am
    I read through Chpater 9 of the manual “Creating MPEG-1 Output Files” and no where is there a mention of 16:9 ratio.
    That is, the manual doesn’t say you CAN’T create 16:9 mpeg-1 files.
    Can you or can’t you? (You couldn’t in Compressor1)
    You can select from two standards; mpeg1 for Web (inc CD, VCD etc) or for DVD. Either way, you can’t alter the frame size.
    So, for example, what if you want to include mpeg-1 on a DVD which IS widescreen? Your mpeg-1 footage is forced to 4:3 aspect.
    Further – and this is my attempted use – I am creating a video in FCP which is 16:9. I want to be able to ouput to Compressor, to produce an mpeg-1 file to send off for preview. This is a standard and traditional workflow.
    So why doesn’t Compressor (1 or now,2) support 16:9 mpeg-1? Other mpeg-1 creators do, such as Mediapress, which I will have to use.
    Thanks …
    Neil Ryan replied 21 years, 2 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    July 15, 2005 at 4:59 am
    Dont’ think MPEG-1 will support 16:9… Can’t you use a more modern codec?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Neil Ryan
    July 15, 2005 at 6:49 am
    [Jerry Hofmann] “Dont’ think MPEG-1 will support 16:9”
    My Mediapress card will make 16:9 mpeg-1 files (in realtime) as will the ProCoder software.
    [Jerry Hofmann] “Can’t you use a more modern codec?”
    As the Compressor 2 manual says, and our real world experience supports, the mpeg1 format offers great universal/multiplatform compatibility.
    If Compressor2 can’t do it, I just wish the manual would say that. And if the standard doesn’t support it (how come some developers do?) then I wish the manual would say that.
    I’d have thought it was an obvious question or at least a Frequently-enough Asked Question to warrant the manual addressing it in some way.
    Thanks anyway.
    T H E P O D
    Multimedia Communciators
