Activity Forums Compression Techniques Compressor 2/ Football game
  • Compressor 2/ Football game
    Posted by Matt Jones on July 12, 2011 at 4:00 am
    I just finished editing a 4-hour football game (w/graphics) that I need to encode to dvd.
    It’s pretty clear that it will only fit on 2 dvds. I plan on splitting it up into two halves. Aside from default 120 minute Compressor, are there any certain settings I should be using, as this is my first venture into very long form editing. Trying to knock down a good look, with each half being under 2 hours.
    My config:
    Macbook (early 2008) 2.0ghz Intel core 2 Duo, 2GB RAM, FCS 2, Standard DV NTSC 29.97fps
    Thanks in advance.
    Matt Jones replied 15 years, 1 month ago 2 Members · 5 Replies
  • Matt Jones
    July 12, 2011 at 4:57 am
    Also:
    MacOS 10.5.8
  • Jeff Greenberg
    July 12, 2011 at 5:40 pm
    You could use a DVD-9 (which should hold your four hours) You’ll want to tweak the 120 min setting to just a bit lower bitrate to fit your video + a menu.
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    New- my book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Matt Jones
    July 12, 2011 at 6:07 pm
    thanks Jeff,
    But I think I’m sticking with 2 dvd’s. If I’m not including a menu, and dropping around two hours on each, what should my settings in Compressor look like. I have some graphics and have used Magic Bullet Looks.
    Thanks again
    Matt
  • Jeff Greenberg
    July 12, 2011 at 6:24 pm
    The Apple 120 Best setting is nearly perfect (both the AC3 and the MPEG2)
    The MPEG2 setting is built specifically to fit on a DVD-5. If you’re at 121 min (or want a menu) you need it just a little smaller – I’d adjust the 5.0 rate to 4.8 and that should free up the extra space needed.
    Hope that makes sense (if not, ask!)
    Best,
    Jeff G
  • Matt Jones
    July 15, 2011 at 5:09 am
    Thanks Jeff
    I ended up splitting it up into first half and second half, and going with two dvds. We’ll see how it goes, and thanks again!
