Activity › Forums › Compression Techniques › Compressor 2 Error Message
  • Compressor 2 Error Message
    Posted by Jared Kirshenbaum on July 13, 2005 at 3:51 pm
    Unable to Connect to Backround Process.
    G4 17′ Powerbook 1Ghz 100GB HD. I was working in FCP5 and went to export using Compressor and then when I went to submit batch, I received that error message.
    I couldnt find anything in the archieves here and looking around the net I saw a couple of solutions, none that worked. I reinstalled software (Production Suite) trashed FCP pref. have enough memory where I am storing this media. Disk disk utility, Tech Tools and Disk Warrior. No help.
    Can anyone help
    J
    Charles Simonson replied 21 years, 2 months ago 2 Members · 1 Reply
  • Charles Simonson
    July 13, 2005 at 8:30 pm
    Check the Final Cut Pro forums on the Cow. This issue comes up often over there (look in the archives as well). I have only experienced this with Compressor 1.2, a long time ago, and the 1.2.1 update fixed it. Also, an update for Compressor 2 was just released just yesterday, so see if that helps.
