Activity › Forums › Apple Final Cut Pro Legacy › Compressor – 16 x 9 setting?
  • Compressor – 16 x 9 setting?
    Posted by Tad Newberry on August 29, 2006 at 4:45 am
    i’m doing an HDV project in FCP and haven’t found a Compressor setting that will give me a small file in the 16×9 aspect ratio to send clients for rough approvals. i’ve been using the Web Download settings which give me good-looking 4×3’s, but it would be nice to send them some proper aspect stuff. thanks if any of you have ideas…
    thanks for helping out a bonehead!
    Carsten Orlt replied 20 years, 1 month ago 3 Members · 2 Replies
  • Shane Ross
    August 29, 2006 at 5:05 am
    Manually change the Aspect Ratio. Get the preset you want then adjust it. Any variant of 16:9…640×360 is an example of what I use…or 320×180.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Carsten Orlt
    August 30, 2006 at 12:23 am
    just load your web preset , go to the frame size panel in the inspector and choose -constrain to 16-9- in the bottom pop up. you’ll see that it will change the pixel numbers in the height field to a lower number making your quicktime the right aspect ratio. if you want to you can save this setting for future use.
