Activity › Forums › Apple Final Cut Pro Legacy › Compressor 10-bit RGB aja to proRes422HQ
  • Compressor 10-bit RGB aja to proRes422HQ
    Posted by Jason Adams on January 23, 2009 at 12:01 am
    I have been using compressor to convert 10-bit RGB aja movies to proRes422HQ w/ 4:4:4 chroma filtering enabled.
    The problem I am running into is the 10-bit RGB aja movies are all broadcast legal chroma and luminance, but after conversion the proRes movies are hotter and more saturated making them non-broadcast safe in both chroma and luminance which obviously is undesireable.
    When I use quicktime player to do a conversion “manually”(same exact settings) it converts it correctly and the two movies are virtually identical in the scopes.
    Any help in wrangling compressor in to convert the movies correctly?
    thanks
    Jeremy Garchow replied 17 years, 8 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    January 23, 2009 at 6:01 pm
    Hmm…
    What happens if you turn off 444 in Compressor? Are you trying to make proxies?
    Jeremy
