Activity Forums Adobe Premiere Pro Compression/Transcoding to diff file formats, which is a better source, IMX30 or uncompressed AVI/Quicktime?
  • Compression/Transcoding to diff file formats, which is a better source, IMX30 or uncompressed AVI/Quicktime?
    Posted by Adrian Tecson on September 22, 2014 at 4:25 pm
    Hi guys,
    I just came across this requirement from a digital delivery service for TVCs. They ask for an IMX30 to be uploaded on to their cloud, which then gets recompressed/transcoded to different file formats such as DVCPro50, DV25, IMX50, etc, and sometimes even get dubbed onto a BetacamSP tape.
    Now I’ve started to question this process as I’ve always believed that starting from the best source, such as an uncompressed file, is always better than starting with a lossy codec such as IMX30. Terms such as compounded compression, digital generation loss, and such, come to mind.
    Here’s a link to the complete article:
    https://www.groupimd.com/en/philippines/why-imd/news/why-imx-files-are-better-than-uncompressed-for-the-philippines-advertising-
    Am I right in thinking this article is more of a marketing move rather than an attempt to be technicality accurate and transparent? Would appreciate inputs. Thanks
    Adrian Tecson replied 11 years, 11 months ago 2 Members · 2 Replies
  • Walter Soyka
    September 22, 2014 at 10:57 pm
    You are certainly right that an uncompressed delivery would make a cleaner source for transcodes.
    However, the ideal format is the one in the delivery spec.
    Having written many delivery specs myself, I’ll mention that after a certain point of “good enough,” workflow, automation and playback realities trump theoretically better (but often perceptually invisible) visual quality improvements.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Adrian Tecson
    September 23, 2014 at 4:25 pm
    Thank you for the reply Walter. You are correct, IMX30 is an ideal delivery format.
    Personally, do you think IMX30 is a “good enough” codec to work with for lossy recompression? If not, what would be your bare minimum?
