Activity Forums Adobe After Effects Compressions options for RGB + Alpha
  • Compressions options for RGB + Alpha
    Posted by Steve Morris on February 16, 2006 at 3:08 am
    What compressions options are available for creating an overlay graphic with an alpha layer? It seems like all that is available to me is NO COMPRESSION wwhen using RGB + Alpha. I am trying to make sets of graphics to keep on hand. A 10 second overlay is 400mb. Is there anything I can do to reduce the file size?
    Realethan replied 20 years, 7 months ago 5 Members · 6 Replies
  • Chris Smith
    February 16, 2006 at 3:09 am
  • Steve Morris
    February 16, 2006 at 3:39 am
    Thanks. I completely missed the format options. I was only looking in the compression part. I also tried a Quicktime file, but it was much larger. Is there a common or typical format used for overlays and lower thirds when they will be used in Premiere Pro?
  • Steve Morris
    February 16, 2006 at 3:44 am
    It does not appear that Premiere will import the png file as a seqquence like AE does. Is Quicktime my best option for Premiere importing?
  • Alexxx
    February 16, 2006 at 5:48 am
    You could also try the old favourite of Quicktime + Animation (set depth to Million colours+) and RGB+Alpha.
    It uses lossless compression, not as good as PNG but still ok.
    Alex
    http://www.lightdrop.com.au
  • Phil
    February 16, 2006 at 4:52 pm
    is png a smaller file than tiff???
  • Realethan
    February 16, 2006 at 5:34 pm
    For RGB+A I use HUFFY-YUV (avi-codec)
    Fast and lossless with a reasonably good compression ratio.
    https://www.free-codecs.com/download/HuffYUV.htm
