Activity › Forums › Apple Final Cut Pro Legacy › Compression Workflow
  • Walter Biscardi
    October 11, 2006 at 5:20 pm
    Simply render the footage in the same codec / frame size as your FCP project. Rendering it in something like Lossless will only result in a larger file which will be compressed down into DV by FCP. I find that any After Effects project looks best when it’s created and rendered in the same frame size / codec as the FCP project.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
