Activity Forums Compression Techniques Compression trouble!
  • Compression trouble!
    Posted by Erin Mcconnell on May 2, 2013 at 1:36 am
    Hi all,
    I have a very large file that I need to get small enough to be playable on youtube. As the source material was hidef, the exported base file was 80+ GB (at only 50 minutes running time!). I have run it through compressor and at an H.264 setting have managed to get it down to under 10GB, which is still too large. No matter what I do, I can’t seem to get it smaller than that without losing sync/widescreen/other attributes. When I run the already compressed 9GB file through compressor for a second pass, it also comes out a mess. I am working against a deadline and am fed up with fighting this file! Any help or advice would be sincerely appreciated. (Ps, I am using Compressor through Final Cut.)
    Ivan Myles replied 13 years, 4 months ago 3 Members · 3 Replies
