Activity › Forums › Apple Final Cut Pro Legacy › compression speed from FCP to Compressor
  • compression speed from FCP to Compressor
    Posted by George Sloan on January 28, 2011 at 4:31 am
    Hi Folks,
    I just submitted a 30minute ProRes project for down conversion to compressor. Imported from
    a timeline that was captured and edited in 1080i. And sent directly to compressor for mpeg settings.
    i am reading 125:27:03 remaining in the batch monitor. Could that be right…125hours?
    Using FCP7 Intel duo core 2.66mhz
    It need to be quality but I am showing a 7 hour compression time.
    THE QUESTIONS ARE.. is this what i should expect? Is there a way to improve this without losing quality?
    the third (and too late now) question is..Will capturing in ProREs speed up the compression process?
    My sincere thanks for helping me in this. George…. sloanmotion.com
    HERE ARE MY SETTINGS..
    Name: MPEG-2 1 Golden
    Description: for Broadcast/DVD
    File Extension: m2v
    Estimated size: 1.49 GB
    Type: MPEG-2 video elementary stream
    Usage:SD DVD
    Video Encoder
    Format: M2V
    Width: 720
    Height: 480
    Pixel aspect ratio: NTSC CCIR 601/DV
    Crop: None
    Padding: (L: 0, T: 60, R: 0, B: 60)
    Frame rate: 29.97
    Frame Controls On:
    Retiming: (Best) High quality Motion Compensated
    Resize Filter: Linear Filter
    Deinterlace Filter: Best (Motion Compensated)
    Adaptive Details: On
    Antialias: 0
    Detail Level: 0
    Field Output: Same as Source
    Start timecode from source
    Aspect ratio: 4:3
    Field dominance: Automatic:
    Selected Top first
    Average bit rate: 6.6 (Mbps)
    1 Pass VBR enabled
    Maximum bit rate: 7.7 (Mbps)
    High quality
    Best motion estimation
    Closed GOP Size: 15, Structure: IBBP
    DVD Studio Pro meta-data enabled
    BlackWhite Restore
    Black: 0.000
    White: 0.000
    George Sloan replied 15 years, 8 months ago 2 Members · 2 Replies
  • Rafael Amador
    January 28, 2011 at 12:41 pm
    Hi George,
    Stop “Sending to Compressor”.
    Export a self-contained movie and import to Compressor.
    Then use the same setting you’ve been using to make your MPEG-2.
    “Send to Compressor” have a big problem: Even if all your sequence is already rendered, Compressor doesn’t use these render files, but it renders everything again.
    This gets worst when you make a “Double Pass”, because everything needs to be rendered TWICE.
    And the worst of the worst, is when, for example, you make a “Multi-pass” H264. Multi-pass for H264 means THREE passes.
    So, you can cut all the processing time going ‘self-contained”.
    rafael
    http://www.nagavideo.com
  • George Sloan
    January 28, 2011 at 2:16 pm
    Thanks my fiend ,
    I’ll try that .
    George
