Activity › Forums › Adobe After Effects › Compression Settings
  • Compression Settings
    Posted by Dave Simpson on April 4, 2005 at 8:36 pm
    Hello,
    I wanted to know how to make the default Compression settings output from After Effects Media 100,
    so I don’t have to change it everytime I add a comp to the render queue.
    I cannot seem to find anything in preferences to do this. I am running After Effects 6.0.
    Thanks In Advance
    Dave
    Dave Simpson replied 21 years, 6 months ago 2 Members · 2 Replies
  • Steve Roberts
    April 4, 2005 at 9:06 pm
    Edit>templates>output module. Same goes for Render Settings.
    You can make a new template for your M100 settings by clicking the “new” button in the dialog. At the top of the dialog you can make it the default if you like.
    It’s often prudent to use “save all” (in the dialog) to save your templates to a file in case you have to trash your prefs to fix a problem at some point. Trashing prefs kills templates.
    Steve
  • Dave Simpson
    April 5, 2005 at 3:47 pm
    Thank You Steve.
