Activity › Forums › Compression Techniques › compression settings on Squeeze
  • compression settings on Squeeze
    Posted by Jack Entonces on January 23, 2007 at 8:30 pm
    Hello,
    I’m using Squeeze 3.5.
    I want to compress a video from my Avid timeline to show on web.
    Would like it to be no bigger than 20mb file size …
    I’ve done it before, but it’s been so long that i forgot.
    I start by exporting my timeline to a QT reference file.
    Then open Squeeze and drag the QT ref file to it.
    Then I don’t remember what are the best settings …
    such as data rate, frames per sec, etc.
    Can someone please tell me what are the best settings to
    get a final quicktime web movie 20mb or less?
    Thank you.
    Reloaded replied 19 years, 8 months ago 2 Members · 1 Reply
  • Reloaded
    February 1, 2007 at 1:40 pm
    Well 20Mb. but what is the duration of your video?
    About the frame rate, I don’t recomend changhing it, leave it at 30fps.
    You can reduce the resolution to 320×240 goog for the web.
    About bit rate (the most important thing to reduce file size), your will have to cauculate it depending on the duration of your v
