Activity › Forums › Compression Techniques › Compression settings for the web…example of my work inside
  • Compression settings for the web…example of my work inside
    Posted by Chuck Purnell on February 5, 2006 at 9:41 pm
    I am new to Creative Cow!
    Below is a link to a EPK I just produced for a client. I used Compressor to compress the footage but I know I can get it to look a lot cleaner for the web than it does now. Its super clean on DVD though.
    Any suggestion as to what I might try differently in terms of settings would be cool. I used FCP HD to edit and export.
    Chuck
    https://www.youtube.com/w/?v=ThtUbi3mJNU
    Ed Dooley replied 20 years, 8 months ago 2 Members · 3 Replies
  • Ed Dooley
    February 6, 2006 at 7:08 pm
    Hard to say what you might try differently in terms of settings when you don’t say what your settings were.
    Ed
    [DVX100Shooter] “Any suggestion as to what I might try differently in terms of settings would be cool. I used FCP HD to edit and export.
  • Chuck Purnell
    February 6, 2006 at 10:15 pm
    I didnt write the settings down…Is there a way I can pull up that info from the compressed file? One complaint I have been hearing is that my current settings take so long to play back and when it does playback it breaks up.
  • Ed Dooley
    February 6, 2006 at 10:31 pm
    I’m a bit confused. You used Compressor to compress the footage, then what? It’s a Flash movie, did you compress
    it in Compressor, then compress it again to Flash? If so, you took a hit in resolution. Again, if so, why didn’t you use
    something like Squeeze to create an FLV directly from the uncompressed edited file?
    Ed
    [DVX100Shooter] “I used Compressor to compress the footage but I know I can get it to look a lot cleaner for the web than it does now.”
