Activity Forums Blackmagic Design Compression Settings Don’t Match Output Settings
  • Compression Settings Don’t Match Output Settings
    Posted by Rick Macadamia on July 12, 2005 at 3:11 am
    I posted this on the Final Cut forum but I think it got lost in the shuffle. Thought I’d put it here and see if anyone could give me a clue.
    After several days of reading manuals and searching on line I am unable to find the solution to this problem. Hopefully it’s a simple fix that I’m overlooking.
    I’m using FCPv4.5 on a dual 2.5 G5 with a DeckLink SP card. I’ve edited a :30 sec. sequence which I am attempting to master to a Sony Beta SP machine, a UVW 1800. When I try to print to tape I get the following warning message: “You may have attempted to output a clip with compression settings that do not match the current output settings. Try nesting the clip in a sequence with the correct settings.”
    The sequence which I’m attempting to master consists of an animation created with After Effects 6.5 and rendered as a Quicktime movie with the video output formatted as Blackmagic 8 bit. I am intercutting this AE animation in Final Cut Pro with film captured at a Blackmagic NTSC 8 bit setting. The setting for my FCP sequence is Blackmagic NTSC 8 bit.
    I notice in the FCP Browser window that the digitized film footage and the sequence Compressor setting are both listed as Uncompressed 8 bit 4:2:2 while the Compressor setting for the AE animation is listed as Blackmagic 8 bit. Is this the source of my non-matching compression settings and, if so, how do I correct the problem? I’ve checked my FCP A/V settings and my sequence preset is listed as Blackmagic NTSC 8 bit. I can’t figure out where I’m tripping myself up and sure could use some advice to get me over this stumbling block. Thanks for any input you might have.
    Rick Macadamia replied 21 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
