Activity Forums Apple Final Cut Pro Legacy Compression Settings and Workflow
  • Compression Settings and Workflow
    Posted by Terry Moore on June 28, 2007 at 3:50 pm
    I have a question regarding compressions setting based on our workflow. Any input would be greatly appreciated.
    We shoot standard def with an HVX-200 to either a Firestore or P2 cards at DVCPro50.
    We import our footage via firewire, edit in Final Cut Pro and output to BetacamSP.
    Does it benefit us to edit Uncompressed or are we better off using DVCPro50 since that
    Shane Ross replied 19 years, 2 months ago 2 Members · 1 Reply
  • Shane Ross
    June 28, 2007 at 4:09 pm
    Edit DV50 and lay off to tape. That codec is very clean, and perfectly acceptable for output to BetaSP. In fact, going out to beta is DOWNGRADING the image, as it is digibeta quality.
    Wait….is DV50 also 720×480? or is it 720×486? Because I know several networks (not that you are delivering to a network) that kicks back stuff that have that 6 line blanking.
    Shane
    Littlefrog Post
    http://www.lfhd.net
