Activity Forums Apple Final Cut Pro Legacy Compression settings
  • Compression settings
    Posted by Jkshooter on January 7, 2006 at 9:36 am
    Hi. I am having problems with exporting movies from FCP 5 using compressor. I went through the handbook and followed the directions to a T. I am trying to export to mpeg 2 for dvdsp of course. It doesn’t seem that difficult but I keep getting the message “Unable to submit batch, unable to connect to background process.” I ve tried a couple different things with the same result. Has anyone had this problem? PLEASE HELP
    Thanks Jeremy
    Jkshooter replied 20 years, 7 months ago 2 Members · 2 Replies
  • Andy Mees
    January 7, 2006 at 3:06 pm
    hey jk
    read this knowledgebase article … it describes your problem ans suggests how to fix it
    https://docs.info.apple.com/article.html?artnum=93234
    if it doesn’t work post back
    cheers
    Andy
  • Jkshooter
    January 10, 2006 at 9:06 pm
    Hi Andy. thanks for getting back to me. I wasn’t quite sure how to disable the disc utilities, do I just drag it to the trash? I didn’t see any option for disable in the disc utilities app. Also as crazy as this sounds, I dont think I have anti-virus software, is there a way to check? Get back to me when you can.
    Thanks JK
