Activity Forums Adobe After Effects compression questions…. please!
  • compression questions…. please!
    Posted by Robert Paynter on October 14, 2006 at 2:08 pm
    I originally had rendered my 1280 X 768 comps out as quicktime movies with animation setting.. then i would put them into sorenson squeeze and use a hd720_lo setting to get them down to 10 mbs and look terrific.. for some reason my sorenso is not taking them this time…
    What can I rerender the already render QT to get a similar file size and quality ?
    Jase replied 19 years, 11 months ago 4 Members · 3 Replies
  • Ron Lindeboom
    October 14, 2006 at 3:58 pm
    I’d call Sorenson tech support and ask why they are not accepting them, rather than switching to another compression scheme and having to recompress all your stuff now.
    Best,
    Ron Lindeboom
  • Roland R. kahlenberg
    October 14, 2006 at 5:43 pm
    Like Ron says, check it out with the Sorenson folks. But I would check to see if your comp size is inaccurate for 720. You wrote, [robert paynter] “I originally had rendered my 1280 X 768 comps”
    which isn’t 720 screen size. You should be rendering out of AE at 1280×720. Perhaps when you chose the hd720 setting from within Sorenson, it baulked – unlikely but something else to consider.
    Cheers
    Roland Kahlenberg
    broadcastGEMs
    customizable animated backrops with Adobe After Effects project files
  • Jase
    October 16, 2006 at 11:40 am
    could try MP4, found them smaller than sorenson (though not the pro squeeze version) for emailing tvc’s.
    J
