Activity › Forums › Apple Final Cut Pro Legacy › Compression Question
Posted by Jonny Filsinger on July 18, 2008 at 4:32 pmI have a 3 hour timeline which I need to put on to one DVD. It can’t be duel layered. In Compressor it only allows 150 minutes maximum. Is there a way around this? Thanks in advance.
Jonny Filsinger
Master Video Productions, Inc.
2832 Bartlett Rd.
Memphis, TN 38134
901-372-7012Jonny Filsinger replied 18 years, 2 months ago 3 Members · 7 Replies -
Mark Maness
July 18, 2008 at 4:56 pmWhy can’t you burn a dual layered DVD?
The 150 minute compression setting is equivalent to VHS tape in quality. Any more compression is going to look really bad.
_______________________________
Wayne Carey
Schazam Productions
http://www.schazamproductions.com
https://blogs.creativecow.net/waynecarey -
Jonny Filsinger
July 18, 2008 at 4:58 pmThanks Wayne. You’re right. I convinced the client to break it in to two halves. Thanks again.
Jonny Filsinger
2832 Bartlett Rd.
Memphis, TN 38134
901-372-7012 -
Mark Maness
July 18, 2008 at 5:06 pmThat’s good.
But I am still curious as to why you can’t put it on a dual layer DVD.
Wayne Carey
Schazam Productions
Alan Thorburn
July 18, 2008 at 5:07 pmI would take your 3 hr audio track into compressor and encode it as a Dolby Digital audio file at 128KB/sec. This will reduce your audio track from about 2GB to 180MB. You will then have most of the DVD available for your video.
Jonny Filsinger
July 18, 2008 at 5:22 pmAlan: If I did that, what setting would you use for the video? Thanks.
Jonny Filsinger
2832 Bartlett Rd.
Memphis, TN 38134
901-372-7012 -
Alan Thorburn
July 18, 2008 at 5:31 pmYou might get away with 3mb/sec for the picture. Try encoding 18 minutes worth and see if the file size comes out to around 400MB, then 10 times that should be about 4GB plus 180MB for your audio and you should be okay.
Jonny Filsinger
July 18, 2008 at 5:41 pmI’m trying it now. Thanks.
Jonny Filsinger
2832 Bartlett Rd.
Memphis, TN 38134
901-372-7012
