compression question
I understand compression some what having used it a lot. It seems as you compress you get more noise is their any tricks to reduce the noise?
What is the best compression settings for a 2 hour movie for a dvd? Is there anything better then compressor? Also what is the best compression for anything under 15 to 20 minutes. I use M peg 2 a lot.Thanks,
Steve
