Activity › Forums › AJA Video Systems › Compression Question
  • Compression Question
    Posted by Dan Archer on January 18, 2006 at 10:03 pm
    Hello, I just made the leap from AVID to FCP. I am used to having different compressions
    like 1:1, 2:1, 10:1 and so on. How do the FCP guys do it?
    Do you all use 8bit, 10bit, DV50 as compression schemes depending on
    how clean the final has to be and how much space you want to use?
    I hope I dont sound just like some other crazy AVID guy,
    and I hope I asked the question right.
    Thanks for any replys…
    Jerry Hofmann replied 20 years, 8 months ago 3 Members · 2 Replies
  • David Battistella
    January 18, 2006 at 10:07 pm
    I use the following
    10 Bit uncompressed 27MB/sec
    8 Bit uncompressed 21MB/sec
    DVCPRO 50 7mb/sec
    DV 3.8mb/sec
    These are the most efficient codecs for use with FInal Cut Pro. They are also optimized for use with the FCP RT engine.
    You can Use offline RT if you have Many hours of material, but even on large docs I just use DV and firewire drives because it looks good and storage is so cheap.
    David
    I can’t believe it’s not butter!
  • Jerry Hofmann
    January 18, 2006 at 10:12 pm
    Offline RT is pretty cool though. 1/8th the size of DV… it’s a photo JPEG compression that is pretty much akin to Avid’s AVR 4 or there bouts…
    I like it because it will work just swell on an internal Powerbook drive and make the whole shebang VERY portable.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
