Activity › Forums › Apple Final Cut Pro Legacy › Compression question
  • Compression question
    Posted by Mark Mower on June 23, 2012 at 3:28 pm
    Is it possible to burn a dvd longer than 2 hours without losing image quality? Total length is 2h 16m. I’d like to use menu screen/chapter markers as well. Just not sure if I would have to use the program Compression or if I can just export a certain way right out of my timeline. Thanks!!!
    Chris Tompkins replied 14 years, 3 months ago 3 Members · 2 Replies
  • Rafael Amador
    June 23, 2012 at 4:02 pm
    You need to use Compressor, although you can “Send to Compressor’ from your time-line.
    Putting to hours of video on a DVD means to compress more the picture with the unavoidable quality lost, however there is an easy solution to avoid this: Using dual-layer discs.
    rafael
    http://www.nagavideo.com
  • Chris Tompkins
    June 23, 2012 at 5:59 pm
    You can fit 3 and 4 hours on a DVD if you want.
    Like Rafael said, it’s a quality to volume ratio. The more you squeeze on the disc, the worse it looks.
    Bring your FCP master into Compressor and choose the 2 hr DVD preset, adjust the data rate to make your long video fit.
    Chris Tompkins
    Video Atlanta LLC
