Activity Forums Apple Final Cut Pro Legacy Compression Question
  • Compression Question
    Posted by Matthew Cook on December 5, 2008 at 7:23 pm
    New to working with 16:9 format. I’m trying to export my sequence for web viewing on my website and YouTube. I’ve tried a lot of different exports using Quicktime and Compressor. So far every setting I’ve tried squeezes the width of the project but not the height so the ratio is way off and it looks bad.
    I’ve read enough on this forum to figure out how to make my sequence in Final Cut match my video and I’ve been able to export a Quicktime Movie with the correct ratio—but at 3.5gb for a 2 1/2 minute video, that won’t work for the web.
    Anybody have a suggestion for either exporting out of final cut or compressing my .mov file that keep the aspect ratio intact?
    Just in case it matters my sequence settings:
    29.97 FPS
    1440 X 1080
    HDV 1080 i60
    HD 1440 X 1080
    Jeremy Garchow replied 17 years, 9 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    December 6, 2008 at 2:44 am
    You simply have to make your movie a 16×9 pixel count. 640×360, 1920×1080, 320×180, 1280X720, 960×540.
    Any one of those will work.
    Start with 1920×1080 (16:9 ratio) and divide each of those numbers to find your pixel count.
    1920/x
    1080/x
    Jeremy
