Activity Forums Compression Techniques Compression program recommendations
  • Compression program recommendations
    Posted by Randy Durham on December 3, 2008 at 9:03 pm
    Hi all. I am looking for the best solution to create 16×9 Flash movies at 768×432 and 512×288 sizes. I would prefer to use Quicktime movies but my clients require Flash. I’ve seen that H.264 movies can play in Flash 9 but honestly I have no idea how to make that happen. So I’m looking for the best Flash movie solution for quality and player size. Also the recommendations on the best flash movie player to use.
    I own Sorenson Squeeze 5 and Compressor but I wondered if some of you with much more compression experience than I can recommend the best compressor and workflow to use. Here are the software solution options I’m looking at:
    Sorensen Squeeze 5 with On2 VP6 plugin
    Apple Compressor
    Episode Pro
    DV Kitchen
    Here are the Flash movie players I’ve found so far:
    Flowplayer 3.0
    JW Media Player
    Any suggestions on which compressor to use and which Flash Player to use are most appreciated. And any workflow suggestions or links to effective compression workflow tutorials are also appreciated.
    I’m hoping to come up with a stand workflow process for handling all our web movies for clients and demos. I lease a streaming server where I can host the files so I’m looking for high quality and the broadest viewer audience acceptance as possible. Thanks for any input!
    Randy
    Terry Griffey replied 17 years, 8 months ago 3 Members · 2 Replies
  • Daniel Low
    December 3, 2008 at 11:47 pm
    Episode with the Flash Plug-in will give you the best results, if used correctly. How much better than Squeeze is debatable and very much source dependent.
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
  • Terry Griffey
    December 5, 2008 at 7:31 am
    I agree with Daniel and also have had very good results with Episode Pro with the Flash option.
    Terry
