Activity Forums Avid Media Composer Compression Problem
  • Compression Problem
    Posted by Duane Fulk on January 7, 2009 at 7:07 pm
    I have a sequence in AVID that I need to export to make a .mpg. When I make a Quick Time Movie and then take it into Procorder for compression like I always do I get the following message “STD buffer underflow occurred. The multiplexer cannot generate a compliant stream. Please check your vit rate settings.” I have tried several bit rate settings both CBR and VBR. There is an animated segment in the sequence that was created in AE. When I export that and try the compression it gives me the same error, so I assume the error has something to do with the animation, but I can’t isolate any bad areas in the animation and it plays fine in the AVID sequence. Any ideas?
    Duane
    Duane
    Duane Fulk replied 17 years, 8 months ago 2 Members · 2 Replies
  • Grinner Hester
    January 9, 2009 at 2:40 pm
    mix it down then export a qt reference file to your encoder.
  • Duane Fulk
    January 9, 2009 at 3:27 pm
    Great idea. Why didn’t I think of it. You always come up with the simple way to do things. I’ll try it this afternoon after this mess I’m in right now!!
    Duane
    Duane
